Anyone know of an addon or setting that lets you specify the colour of a polygroup?
While caring out your function you can press the Alt key and the polyface will change colour. Or… you can hide the faces you don’t won’t and Ctrl+W
No. Just keep assigning a new polygroup until you get a color to your liking.
If using the ZModeler polygroup action to assign polygroups, then tapping Shift after maikng contact will sample a polygroup color for use elsewhere. Continuing to tap ALT will continue to assign a new random color.
do you want the color of the poly to always be bright?
