Wondering if a plugin can be made that will randomize an insert multi mesh brush set one brush object from the set onto a polygon of the base tool over the whole model - and maybe a button to check for a starting point to start applying the imm brush set AND maybe not to apply on area(s) that are masked out. Even though the IMM brush set makes it easy the objects as seen in the gray and white image where done one at a time (over 780 in the image and only on one side)
