I assume that it’s not possible, but I use a plugin that is no longer supported and does not work with anything beyond ZB 2022. The author of the plugin does not respond.
Any suggestions or workarounds to this type of error when trying to use the plugin RefSwitrcher in zbrush 2025?
OR any suggestions of workflows or other plugins that do the same thing: quick switching between saved cameras/spotlight images?
I almost get what I need without a plugin from:
- DRAW>CHANNELS>StoreCam with Load Image and Store Image
But this does not allow use of spotlight images, which would be OK except the model opacity cannot be toggled to zero (so you can’t switch between the pure reference .jpg images and the pure sculpted model)
Thank you!
USING DRAW/CHANNELS/STORCAM w/ STORE IMAGES cannot achieve 0 opacity.
Need to be able to see the unobstructed reference image. At min opacity (1%) it obscures the reference.
