i need hide some unused menus. who can help me?
please offer me a script to hide menus,after i made some coustom UI, my menus is too long…it have occupied two lines menu. occupied too much screen area.
I’m not sure what you are trying to do. Can you explain a bit more or post a picture?
Thanks,
That might be a Monitor resolution issue. Or you have both side palettes open, which could cause that if you don’t have enough screen space.
You can hide all the menus by pressing the orange ‘Menus’ button at the top of the UI. So to have just the menus you want showing do this:
- Press Enable Customize in Preferences.
- Ctrl+drag the menu titles you want to show to the line below. It will be highlighted when you drag into it.
- Unpress Enable Customize and store your custom UI (Shift+Ctrl+i).
- Press [turn off] the Menus button any time you want to reduce interface clutter. You can assign a hotkey to this button for quick access.
