please help, I can't see my obj. in maya!!
I have imported a mesh from maya and then sculpted on it in zbrush, i have then tried to export the lowest res mesh back into maya, in the export menu i keep scaling to 1, i untick Grp and texture, when in maya i go to import the obj file, maya seems to import it but there is nothing on the screen, i just want the low poly mesh in maya from zbrush, no displacements no high detail, just the low res mesh from zbrush in maya!!
ive looked all over the web and i cant find anything on it, so someone out there who knows the solution to this, i would greatly appreciate some of your knowledge! thanks again!
Check the size of the output file!
First. It isn’t so small, that you have to zoom in massivley?
It isn’t so big, that you have to zoom out massivley?
If both isn’t the case, than please press one time “import” in the tool palette. Chancle it. Than press “export” or Goz and try it again.
I also get the same problem. i think you have selected wrong render layer. try to select master render layer and you can see what you cant see before.
