This is just a small doodle to show the plasterstone material.
Use your own material texture- and surface bump images to experiment with
it.
and this is the material
it.
this is a very convincing material… thank you for sharing it!
Excellent material … Thanx a lot, i just love this one. Keep em coming 8)
jantim - very cool! i may use this for my crouching figure. thanks for sharing.
r
Thanks for sharing this Material, Jantim. I think you posted an earlier version if I am correct which I had meant to play with but this pic you have posted with a new version of the material has my jaw working overtime. I have had an idea for a pic and the first version was close to what I had in mind but this one I think is gonna be the cat’s meow.
Thanks!! I only hope I do it justice.
i did a test render with this material… it’s fantastic…
very intuitive use of cavity shaders!
thanks for sharing
It make’s me happy to see that you all like this material:)
I hope to see your models with it,…that is a good looking dragon ,testure
jantim
In the original material i used one of my images, i changed this image for a
default image in Zbrush textures, i was afraid that the material file would be
to big !
I saw that these new images make a “tiling” line in the material, if you want
to use my original image for the material texture and surface bump channel i
post this image as a zipfile , just replace the images in the shaderchannels
for this texture…for the surfacebump you have to make an alpha from this
image !
If you don’t want to change all the settings the small tile-line can be removed
by pasting the new ,or your own, image in the surface bump channel of S4.
That’s an alpha image, this should do the trick and it should look as this:
cool shader. i really like the first image you posted, jantim. awesomeness!
dado
What a great shader! Thanks!
Great images
small_orange_diamond
and many thanks for sharing!
Many thanks!! :eek:
Looks amazing, may I ask where I can get this material?
