The original HD Render All script has now been updated by marcus_civis as a plugin. This is for rendering all subtools with HD Geometry if used. It makes it possible to use perspective for the render.
This plugin is now available for ZBrush 3.1 PC and ZBrush 3.12 Mac.
You can get it from the Download Center.
Installation:
Unzip the zip file and place the .zsc file in your ZBrush3/ZStartup/ZPlugs folder. Restart ZBrush and the Render HD Geometry sub menu will be at the bottom of the Render palette.
Using HD Render All:
You must have a polymesh loaded for the script to work. Draw it on the canvas and press ‘T’ to enter Edit mode.
Adjust the position and perspective of your model.
When ready, press the Render All button. When the render is finished, export the image from the Document palette.
Pressing the Reset button will clear the render and restore your model to Edit mode.
To render a turntable with HD Geometry use Turntable Plus.
We hope you find the plugin useful!
