Hello! ZBrush 3.1 continues our pursuit of artist focused and artist driven tools. Here I would like to share with you some of the notable features we added:
- New Brush Palette that allows users to load and save their own brush presets
- New Brush features such as Color Masking and BackFace Masking.
- User Assigned Hotkeys
- ZMapper
- Displacement Exporter
- Poseable Symmetry using Smart Resym’s Topological Symmetry feature
- A New Mesh Relaxation Tool: Reproject Higher Subdiv
- Support for square alphas while sculpting
- Support for sculpting with both ZAdd and ZSub
- Mesh Projection now projects PolyPainting
All brushes are now represented by icons. Each brush can be saved as you modify its settings. Save the Brushes in the ZStartup/BrushPresets to have them load automatically at startup.
Color Masking uses the polypainting on your model as a mask. A powerful feature for more subtle texture painting of your models.
BackFace Masking is very useful when dealing with thin edged models. All polygons with their normals facing away from your brush will be masked off and not effects by your sculpting strokes.
Assign your own hotkeys using a few simple keystrokes. To start, press CTRL and click on an interface item. Then press the key you want that interface item assigned to. Its that simple!
To save your hotkeys press Store in the Preference: Hotkeys sub-palette.
You can also assign hotkeys to custom palettes or palettes already in ZBrush. By default F1-F6 are assigned to ZBrush’s most important palettes.
Learn more here.
ZMapper
Generate normal maps for any game engine or 3D program using ZMapper.
Learn more here.
Export 32, 16 and 8 bit displacement maps as well as convert grey scale maps to normal maps using Displacement Exporter.
Learn more here.
Poseable Symmetry allows the user to work in symmetry when the model itself is posed or otherwise not symmetrical. Using topological symmetry, your sculpting on the left side will be reflected on the right side of the model.
To use, simply set the symmetry axis in the Transform palette and then press Transform: Use Poseable Symmetry. Make sure to do this at the highest subdivision level. If you divide your model again simply press Use Poseable Symmetry to re-establish your symmetry in pose.
Learn more here.
Use Reproject Higher Subdiv to relax your mesh’s topology and reduce polygon stretching. Simply lower your Subdiv level and press Tool: Geometry: Reproject Higher Subdiv.
You can also try smoothing your mesh alittle bit to help reduce the polgyon stretching even more.
Sculpt with square alphas by setting Focal Shift to -100!
Sculpt both in and out in one brush stroke. Simply set {{Ctl|Alpha: MidValue}} to 50.
Using Mesh Projection you can now transfer PolyPainting information from one mesh to another. Simply make sure that RGB is on in the shelf or Draw Palette.
Happy ZBrushing!
Ryan
