Pilouresque
Pilou, changed my mind about automatic drawing. Would not have been without you and your link to Apophysis ;)!!
This could be a challenge: just look at those pics and then work out what’s shown, but: since this is kind of personal >>
small token for you, Pilou
Edit: it is not (NOT) a monster, even if it is shown here :D, the poor creature has got this irreversible hickup - best reason to stop any monstering!!
Hi Zaphod
thx :slight_smile:
Not a monster !
A sort of Gargoyle :smiley:
Take a look at this wonderful site :eek: :eek: :eek:
Have fun surfing!
Pilou
ps can you take my “red” Apophysis image,
Import it Zbrush
Grabb it
Create an object 3d
and save it for embeded the texture
Post the result
So I will can make your funny challenge :slight_smile:
I am thinking about 3D, doing 2D. It’s addictive
Think the real challenge is seeing all there is - seems to be a thing on end.
… you turn around to look into
don’t worry, was the last one for some time.
:+1: :+1: :+1:
More post it :sunglasses:
Pilou
Ps And me I am thinking of 2D doing 3d!
But as a demo user I can’t import Image !
So thx by advance if you can make that I have writed in the post above :slight_smile:
Because I can load an 3Dobject with texture embeded !
… you asked for it (thank you, Pilou!!) :wink:
(there is this darn vertical border, saw it to late, sorry)
Pilou, my brain is fractalised (downloaded some extra formulas - it won’t stop!!): PLEASE, what thread for your red thingie?? Thank you!!
EDIT: Pilou, just tried it with one of my forms, and: no use! Those fractals are way to detailed - you can’t keep ZBrush from turning those fragile forms into one solid clump - ugly!! Sorry!!
Hi Zaphod
Sorry, it was in the last post of this page :slight_smile:
I have believed that you had seen it :rolleyes:
Pilou
ps I have not the same advice about the 2D to 3d :slight_smile:
So take me my red image :slight_smile:
Pilou, I had seen it and now I have it. Will give it a try (allthough all my fractals did not make it “big” in ZBrush: the best version resembled something like a selfpropelling Ommelett :)!).
I’ll be back with the results of converting your red thing. :wink:
Beutiful post Zaphod ¡¡¡
Congratulations
Andreseloy
ps: all is ok¡ thanks.
Thank you Andrè (good to hear!!). The software I used (in case you’ve missed it) is called “Apophysis”, it is FREE, and you can get it at
http://www.apophysis.org/
There are additional formulars available to widen the possibilities of fractals.
But: be careful >> it is addictive, I spent nearly the entire weekend going from one fractal to fractal!! You should try it, I am sure you will like it!! :wink:
Hi Zaphod
I believe that is here a public formula data base Formulas that you can add to Apophysis ? :slight_smile:
I don’t try ( 4.4 Mega of formulas :eek: :eek: :eek:
And you must be connected to the Web Apophysis FAQ
This can be useful too :slight_smile:
World of fractals is some gorgeus :slight_smile:
Pilou
PsYeaaah ! From this link You can see that you can load
.fla and .ifs file :slight_smile: :cool:
pss So you are became a
Deviant artist :cool:
:smiley: … so you found out about the “right” file types for Apophysis! :smiley:
And Deviant: sure, it’s great - makes me wonder why allmost nobody works on them fractals! There are so many forms emerging in just one single fractal, with just a bit postwork you can make them “visible” for everybody. but most of the artists there don’t bother about that.
True, there are some fractals that even I don’t touch - simply to beautiful to mess around with!!
Hi friend I downloaded the program,the picture you have made are wonderful. Soulet has posted one with background from Apophysis and also beutiful.
I will read the manual¡¡ see you¡¡¡
Thanks
Andreseloy
Andrè, you are welcome, anytime!
For the handbook: it will do no harm reading it :wink: , but to use Apophysis you just sit down, start the proggie, open the editor (so you can shift those triangles around) and press F9 for random generation. If you are not satisfied, just alter one or all of them triangles, or: F9 again for the next random experience!
Don’t forget to export your fractals that you like most: it happened several times, that I hit F9, not thinking about the fact that afterwards the old fractal vanishes!! :smiley: :smiley:
It is really GREAT fun (and relaxing, too!!)!!
EDIT: forgot >> tried to use more then just a bit of postprocessing and landed on a small spot, somewhere in the void:
it is only a test for the use of those fractals, no postprocessing on this one. :wink:
Beautiful images, simply breathtaking.
It will be interesting to see if the new version of zbrush can produce thing of this nature.
Hi bicc
NO because Apophysis background image is a result of a calculating of an mathematical equation “point by point” !
But of course you can try to simulate the same aspect by some brushes but you can’t have the same precisely result :slight_smile:
Or maybe by a script but this one will be very slowly !
Pilou
ps cool last image Zaphod :cool:
Thanx to all of you, but: it really is Apophysis that deserves credit. Without it – nope!
And: Pilou I am glad that version 2 will not be able to do this. Software like Apophysis - free for everybody and bugfree - is not encountered every day. ZBrush has that many benefits, it can’t simply do it all. For good!!
Hi Zaphod
Ok I have re take my Red Picture (Thx Juandel) made with Apophysis :cool:
Alpha Make3D (Double Enable)
Redraw with texture transparent Enable
Drawing some 3Dobjects resultant
Play with the Adjusment
Et Voila :slight_smile:
So apply an altitude to an image 2D is not so bad :smiley:
An another try with the same Red Picture is visible here :slight_smile:
Re use any image with the Alpha make 3D is infinite :cool:
Have fun Zbrushing!
Pilou
Ps
Frame is not Zbrush :rolleyes:
But you can make same texture with the Texture fabric by Cameyo !
Well - some colours whirling around there!
I don’t know how to say it - I like this sort of pics, too. But just look at the fragile appearence of those fractals!
What I mean: there is a proggie that does it, and it does it in a way that I could not wish for more - so I have almost no motivation to see if another of my softwares can do the same.
Nobody is writing letters in Painter, nobody will do a diagram in Vue - I can use those fractals - even those that I have changed - as a background in any program, even in ZBrush, what more could I ask for?
I tried to make those fractals 3D just out of curiosity, and I was not happy with the results. Your picture, well I believe you can take any source, bring it to ZBrush and achieve similar results. The magic of the original will be gone, replaced by something unique from ZBrush. That’s quite allright but for Apophysis - there’s nothing but the original, don’t you think?
Hi Zaphod
Of course the original is go away :slight_smile:
Just a re use in fractal way !
(in the meaning that “all is inside and vice versa” )
A changement of size(a sort of close up) and treatment :slight_smile:
And you right Apophysis rocks for “smoking light” images :cool:
Pilou
Ps Take a look
Here :slight_smile: (slide the page)
It’s not fractal but you can make some cloudy form :slight_smile:
And you keep the control against a fractal prog where you just introduce a formula :slight_smile:
