pick color from outside Zbrush
Hi, is there a way to pick color information directly from a google image? I have tried dragging from the color palette, but it only picks black color if I drag outside the Zbrush Interface, and currently I have to print screen my color references, look their values in PS an the type them manually in Zbrush (with is not such a hassle, but it would be great if I could drag my color values directly)
Save and then load the image into ZBrush, then you can.
A couple things you could do…
As a document…
First select the ‘Flat Color’ material then go to ‘Document’ menu and click ‘Import’ to import your image.
As a subtool…
Select the Plane3D tool and draw it on the canvas. Fill it with ‘Flat Color’ material. Go to ‘Texture’ menu and import your image. With the Plane3D selected, go to ‘Tool > Texture Map’ and apply the image.
