Hi guys just wondering about the perspective settings you all use when modelling things in zbrush. I want to avoid things looking totally different when i export my model over to maya. Also does the perspective distorion vary depending on the size of the model? sorry if this issue has already been posted. Thx
The only thing i have read from ZB4 in shadowbox is to press P Key to work in ortho than perspective view besides that proably not to much relevant in zb but no test with the new version
the hotkey p it to change from ortografic to prespective.if you want to change the angle of prespective to match the angle you use in your camera in you apllication ex:(in maya go to camera and see what focal lengh is there) and use the same value in zbrush.you can change it in the menu DRAW .theres Focalangle values there.
hope it helps
