Hi everyone, it’s my first post here, I’m still a beginer, so I encounter some problems from time to time. This time I accidently pressed some keys on keyboard, and I belive I turned on some weird option which I cannot switch back off. The problem is that when I have perspective turned off, square base of a model takes some trapezoid shape like in reversed perspective, the angles are different than regular 90 i should see (marked in red). When I turn perspective on, eveything is as it should be (closer things are bigger etc. ) but when I turn it off mentioned problem occure every time. I need to sculpt it without any perspective, so I turn to you all for help
EDIT: I forgot to mention, Preferences > Init Zbrush, Zbrush restart, and computer restart did not help. Anyone have an idea what could survive such tries?
EDIT 2: After 48 hours frustrated I just reinstaled zbrush and it helped Thread can be closed / deleted
