I’m having an issue with the panel loops option. I’m following an online tutorial, we began by using polygroups to group off certain areas for geometry where the loops would go. However once I try to use the panel loops option it crashes my zbrush, or its hides certain parts of geometry, or all of it, and then crashes anyway. Iv tried resting my program as well as my computer. I have also created some primitives mad 1 or 2 polygroups to test things or, sometimes it will work but delete alot of geometry in the process. What should i do to make it work?
This is the before with the options stated in the tutorial and what happens after, if its doesn’t crash on the spot, but if i try to do anything it intimidatingly crashes
Why are you using something that is now four versions out of date? You should upgrade your license to ZBrush 2018.1.
