The “Paint” Brush
Auto Masking is turned off, still get the warning message that it won’t work with Sculptris Pro mode.
Are there other auto masking settings besides Brush> Auto Masking that need to be turned off?
Hi!
Which Auto-Masking is turned off? Auto-Masking is an entire menu with individual sub-options, most of which will interfere with Sculptris Pro mode. None of them should be enabled by default for the 3d Paint Brush, though.
Auto-mask Mesh insert and Auto Mask Fiber Mesh are enabled by default in the program and won’t affect Sculptris Pro mode.
You can return a brush to its default settings at any point with Brush > Reset Current Brush. Note that by default, the Paint Brush does not have ZAdd enabled, so it won’t add sculpting information unless you switch that on.
