I recently developed a zscript to fit my workflow needs. this zscript comprehends:
NEWS!! RELEASED TO THE COMMUNITY.
Instalation
Unzip the installation zip to the ZBrush2 directory into ZStartup\ZPlugs(create any nonexistent folders).
It will start everytime you start Zbrush.
This image shows the three buttons (and the M+, that’s the Svengali plugin) that will be added to the ZPlugin palette under the name Brush States [Version]:
the Save brush conf. saves your current configurations.
the Load last brush loads the last one you loaded, just in case you tweaked it and want to return to work with the saved one.
and Load conf. file. brings up a dialog for you to select the preset you want to work with.
Ps. I recommend to drag them outside the canvas with the ctrl key to avoid the hazzle of having to open the palette everytime you want to use it, like I did.
I’VE IRONED OUT THE BUGS. WILL TRY ON ANOTHER PC ANYWAYS. IT’S WORKING QUITE WELL FOR ME NOW EDIT CURVE WISE. LET ME KNOW HOW IT GOES!!
