Hi everyone (I hope this is the correct forum),
I would greatly appreciate anyone’s help on an error that’s preventing me opening one particular project - a project I’ve been working on for over ten days!!
Whenever I try and open this project I receive the following error alert:
“Out of disk space. Virtual memory file can’t be used until more disk space is made available. It is recommended that you save your work and restart ZBrush.”
I press ‘OK’ and ZBrush then crashes, every single time I try (including several re-boots).
ZBrush is installed on the main single non-partitioned C:drive running under 64 Bit Windows 7, and the drive has 1.06 Terabytes of free disk space, (so it obviously doesn’t require more disk space). The processor is an Intel i5-2310 CPU 2.90GHz, running 6GB of RAM.
Please help me to have NOT lost my last ten days work.
Thank you everyone.
Darrell.
