Organizing Root Directory
As I was installing ZBrush 4R7, I accidentally forgot to create a folder in my hard drive for ZBrush to install to. When it finished installing, I realized the files have been scattered within the hard drive. The software itself works perfectly fine.
If I tried organizing my hard drive and putting the files into folders, would that influence the performance of the software at all? Would a problem with ZBrush occur if I tried organizing its root directory?
Also, just out of curiosity, what would the process for reinstalling ZBrush be like? That is a possibility I am also considering.
Many thanks in advance!
By Default, when it installs, files are placed in more than one location. If you didn’t change anything at the prompt when installing, all is as it should be. :wink:
Thanks! I’ll leave it as is then. :slight_smile:
