Hi friends.
I’ve a question for you:
In some posts there 're zscripts or test material, I take it and open, there’s a code inside. What I’ve to do with it to see the zscript or use the materials?
Thanks in advance!!!
Hi friends.
Those are ZScripts. You need to start ZBrush, press ZScript>Load, and then load the script. In most cases, it will then open at the bottom of the ZBrush window.
Hi aurick, how are you?
I did what you tell me but nothing happens.
Open file and save it. Start zbrush/zscript-load script/I find the file saved and open, but nothing appear.
Thanks for your time!!!
hi Axl,
what zscript are you loading. if it’s an older one it might not work with z2.
If your canvas goes to bottom of zbrush window, you might need to move the bottom up so you can see the zscript buttons when you load one up.
Hi aminuts!!!
Thanks for your information, but I’m afraid is not the case.
I’ve been trying with Jantim’s material, is not as old. And yes, I move the bottom of my screen up and down but nothing…
I’ll try again
hi…can you post the link to the zscript you are trying to load? that way I can see what the deal is.
Yeah, here it is:
http://www.zbrushcentral.com/zbc/showthread.php?t=21692&page=4&pp=15
I’ve been triyng with " red paint rust.zip "
You’re trying to load a material as a script. Try loading it as a material.
sscreener is correct.
unzip the file and place it in your Zbrush/Materials folder
start zbrush and choose a material (so you can use its slot).
in the materials menu choose import and select the red rust paint material. it will now be loaded and ready to use.
Oh!!!
Yes you’re right. I’m ashamed :o
Thanks yall for your help
