[video=vimeo;215360965]https://vimeo.com/215360965[/video]
Open source project initiated by Oliver Hotz to copy & paste points and polygons, with respective attributes, across multiple apps.
This is not an asset transferring mechanism but an on-the-project quick way to transfer geometry without file management concerns (You don’t file manage your clipboard right?). A bit like GoZ, but not focused on Zbrush.
Check it at: https://heimlich1024.github.io/OD_CopyPasteExternal/
Initially the developer wasn’t foreseeing working it out for Zbrush, since if I’m correct, there’s no Python here. So I’m probing you to know what are the avenues available in ZBrush to tap into this project.
Thanks!
