.OBJ organizer?
I am looking for an app which can catalog .obj files. If there is an app which simply creates a .jpg with the same name, that would be cool to.
Tests to do that with ZScript have failed miserably as I fail to be able to hand a filename to IPress,Tool:IMPORT… Sighhhh. The ZBScripting language must have been forged in a dark place… M.C.'s skills are definitely SuperHuman!
Cheers
Lemo
Can you describe what you mean by catalog? I might be able to help you.
:slight_smile: You need to use the [FileNameSetNext command, something like this:
[VarDef,filename,""]
[VarSet,filename,"fullpath\model.obj"]
[IButton,"Import OBJ",,
[IPress,Tool:PolyMesh3D]
[FileNameSetNext,filename]
[IPress,Tool:Import]
Of course, that doesn’t solve the difficulty of finding the file name & path in the first place…
Great Marcus!!!
That did it. I actually generated the script with a small VB script lol.
So I have not tackled that directory parsing problem in ZB.
Now it runs through a directory, loads every .obj file one after the other, plops it onto the screen, scales it to the max, saves a bmp, and continues.
In the end I have a directory with all the .obj’s and .bmp’s with a picture of them. When I go into the directory with the MS Thumbnails set, it neatly shows all the pictures and I am having zero difficulties finding a certain mesh again… Memory does not seem to be a problem as I import the new .obj while the old one is still selected. Speed is alright. Better then doing this manually… It’s really a shame that ZScript is so awkward. I never could really warm up with it…
Lemo
Hi Lemo,
I’m glad to help. :slight_smile: It sounds like you’ve made yourself a nice little cataloguer. On ZScripts, they can be quirky. Perhaps you’ll have better luck writing plugins for Carrara! :wink:
Not really… The compiler for the Mac version is not available any more since this month. SO… they have to move to a more modern platform there. Till then… I’ll stay low ;-). But XSI has an interface for an SDK and 3 different (Python, Java, VB) scripting languages. That’s my animal of choice right now for enhanced mesh and brain bending 8-).
Lemo
Lemo,
Here’s a link / solution to a similar .obj cataloging discussion over a year ago…
Sven
Thanks! Great idea to display all four views. I’ll go back to the drawing board for that one. Funny that there is no solution out there… I can’t be the only one drowning in models hahaha.
Lemo
Deep Exploration at http://www.righthemisphere.com will generate thumbnails from many different formats, including OBJ. I know $149 is not cheap, but it is primarily a file converter.
Here’s a cheaper one, 3D Photo Browser, I just came across at http://www.mootools.com I have not used it yet, but it looks like it might do thumbnails, and it converts files too. They have 3 levels, $20, $29 and $49.
Chris
