First let me explain why i’m trying to do this, i don’t like having to switch between my tablet and my keyboard, i try not to use it as much as possible, but you need to if you want to enter values into zbrush’s sliders.
So I searched for a way to do this within zbrush and discovered Mulvo’s Zcalculator script, which sometimes can set the numbers punched in into a slider. However, its old and will not work with the Deformation sliders, which i really need it for.
Is there a way to do this? I’ve so far heavily mod/cannibalized his script to make it a plugin hoping this might help eventually. I’ve removed the calculator functions. but have retained his “set” function.
As it is right now, it has buttons that function as a plugin and in the zscript window, unfortunately the numerical display only shows up in the zscript window, is there a way to make it function in the plugin palette? I’d rather have it as a plugin in the end.
Also could someone help me with getting the values to enter the Deformation sliders, it also only works half the time in other silders and sometimes adds an extra digit.
Yes i’m a total noob to zscripting, but not zbrush. Hopefully if/when this works it could help other users who don’t want to keep switching hands.
Thanks to Mulvo for his script, it taught me a lot so far.Link to his zscript:http://www.zbrushcentral.com/zbc/showthread.php?t=3916&highlight=calculator
