Noob Question: Sudden Glossiness?
Hey, so I started making a model in Zbrush on a different computer than I noramlly do a couple weeks ago, and everything was all fine and dandy until I saved my model and loaded it up on my home PC. For some reason it added an intense gloss to my entire character that wasn’t there on the previous devise. The last thing I did before the move was start painting the model, but there was no shine at all at that point. I was using the SkinShade4 material at the time, and now materials don’t seem to have any effect. Basically I’d just like to remove the gloss as it really subtracts from the model, all help is appreciated :slight_smile:
(Idk if it matters but I was working on a cintiq, and now I’m on my pc with an intuos pro)
When I open some of my older projects or tools , an old material, stays stuck on tool, The only way I found to fix is, take a paint brush, paint over the whole tool with 1% mrgb, old mat disappears, Save file out, re open. Hope this helps
You can also try the fill mat button under texture map menu.
