Hi, I was wondering if anyone can help me with re positioning the noisemaker window, when I open noisemaker the top of the panel is not on screen and I can’t access the topmost options. I have scoured the options in zbrush finding nothing and there is no way for me to grab the window and shift it, also I have tried every resolution on my monitors to no avail. I hope this is an easy fix as I need to use this amazing tool!
Another guy had the same issue, maybe this will help in your case too
Thread > http://www.zbrushcentral.com/showthread.php?190872-Noise-Maker-screen-can-t-see-it-all
I’ve been through all the threads and followed all advice with no success. Both my monitors are 1920x1080 so it’s not an obvious resolution issue and I’ve assigned the noise function a hotkey but still get the same problem. I have found a way around the issue, though it’s a convoluted process, first I reduce my window so it floats on the desktop, then I access noise. The panel come up with the topmost options accessible allowing for use. Once complete, press enter to validate selection, apply noise if seen fit. It gets me through, but it’s a stint in my workflow.
@Jdeus666. Windows or Mac?
windows 7 using Zbrush 4R6
4R6 it worked fine for me and so does 4R7(position wise) Why aren’t you on 4R7?
I want to upgrade but have to find what e-mail address it was registered under as the program came with a computer package from my educational institute last year. I have the serial number so all I have to do now is to chase down the teacher with the info for the email.
