I want to use the noise maker to do some mask, like(Hex tile).
But when I adjust any value ,Zbrush is often to crash without warning.
My zbrush version is 2019 and 2019.1 the same errors. (win 10)
Please try using ZUpgrader to check and see if an update is available. There was a minor update pushed out late last week which may well resolve your issue. (You should be on ZBrush 2019.1.1)
If you are having this issue with 2019.1.1 then please submit a Support ticket so that our team can communicate directly with you to try and find the cause so that it can be fixed.
Thanks!
Thanks Aurick. I try to Zupgrader, but it looks only update to 2019.1
