Hi
This will probably be the fourth thread I’ve started that won’t get acknowledged.
With ZBrush’s Surface/Noise Generator, is there no way of being able to adjust the rotation, offset or scale if you use UVs and an alpha? It only seems to work with a Noise Plugin, but I want to be able to rotate an alpha pattern around, but it doesn’t do anything.
Is it possible to do some way?
Thanks
