No GoZ button in Maya 2009
Maybe I’m doing something wrong, I followed all the steps for goZ in zbrush but when it was time to send the model back into Zbrush. I did not find the button for this.
Is there something I am doing wrong? (I am using Maya 2009)
Thanks for any help.
Same problem here, I’m using Maya 2009, I’ve installed the plugin through zBrush, I can send a model from zBrush to Maya but there is no GoZ button anywhere in Maya, so I cannot send the model back to zBrush… :confused:
A little help would be appreciate.
I tryied to install the plugin into Maya 2011, this time when I launch Maya, a dialog appear saying that a new GoZ tab is been added to the shelf, but… The tab is EMPTY! :mad:
Is this plugin ever been tested?! :rolleyes:
Same issue here.
When I auto-installed the GoZ plugin for maya 2009 64bit everything worked fine. Maya opened, model appeared, new GoZ shelf + GoZ button. It was lacking a shader, but thats simple. When I extracted one of my creatures feet it crashed. It happens. Open Maya again and the shelf is present but the button is gone. I add the script to the shelf manually and it doesn’t work. Deleted the script, cleared the cache in zBrush, reinstalled(auto) the plugin and the button is still missing.
Go here, http://www.zbrushcentral.com/showthread.php?t=92103
Try out some of the solutions provided in that thread.
I meet the same problem and I found to resolve the issue.In zbrush you found the preference/goz, force reinstall.then check out the option under administrator,ok you can translate from maya to zbrush.
