I’m trying to model a head from a photo. First thing i did was to export V3 mesh (from poser). The idea is to use the object as a morph target in poser.
I began to work with zbrush, and i used my refernce photo as background. Then, i exported the .OBJ as a tool, and draw the face. The problems is, i need to make it transparent, so that i could model from the background photo. I tried using 3D copy, but it’s useless, because the texture moves as i deform the object. I need that picture in the background remains still. If someone could point me in the right direction, i will be very appreciated.
hi welcome lord kain,
here is one way you can go.
- place your reference in one layer ( for that, for example, choose plane tool, make settings same aspect ratio as your reference, choose as texture your reference and flat material…draw plane)
- make new layer. turn in render panel “flatten layers” OFF.
- choose basic material, and in the settings put transparency some high value, like 60…
- choose your head model and draw on layer, go into edit mode … now it should be half transparent, letting you see your reference image …
happy modeling
Hi Lord Kain Welcome¡¡
here is a script that is essentially what Kokoro already has pointed¡ Press in the script panel “Show actions and notes” to see step by step.
Thanks for your attention
Andreseloy
photo.TXT
Thank you very much!!! It worked!!!
