Newbie Help Required Please!
Hi
Id really like to create some stitching on a model that I created in Marvellous Designer and imported into ZBrush. Im a total newbie here, and wondered if I need to create stitch brush, or do I use nano meshes?
Any guidance/tutorials would be appreciated!
Many thanks
PR
Hi - I am new also. But I have seen the IMM Curve brush has some stitches, as well as the StitchBasic brush. You can change the setting for each of these also to fit your needs. Hope this helps.
Thanks a lot for that! I did some experimentation and that curve insert brush did the trick!!
