hi guys im new to Zbrush and im working in 4r7 and have been having a few issues. Basically i dont know why but my clay is very pixelated and when ever i use poly paint the colour is blurry, i dont know what settings i need to change as im new to the softwware. any suggestions would be a massive help
Hello, I guess:
- You have to increase your UV-map size (8192 is highest possible)
Tool > UV > UVmap size - And your our Texture Size
Texture > Width
The third “size” thing you can struggle with is the Document resolution, which comes into play, when you grab sopmething from your current canvas.
But this will come a bit later (was my own issue today with alpha creation by grab document)
Because these are so important, I have put them in my Custom UI at the top bar.
Poly paint relies on actual geometry as you are painting the vertices. I looks to me like you simply don’t have enough points. Divide at least once more and see if that makes a difference (to new painting).
