newbee question
Hi
Im a little new to zbrush i’m stuck i was working on a model and now it just duplicates can’t get to the edit button anymore i sure it a simple fix can anyone help?
What’s happened is that you have left Edit mode and that instance of your model is now pixols on the canvas. As long as you remain in Draw mode, your Tool (model) is a 2.5D paint brush rather than an editable object.
Press Ctrl+N to clear the canvas. Draw the model again. Then immediately press Ctrl+T to enable Edit mode again. You can now return to sculpting.
Just FYI that you may also find that you have a bugged model that is causing similar problems. At least that is what happened to me.
