I installed a new 970 card yesterday, 4gb ram awesome , can now work with fibermesh for hair, but Now that I am at hi res , 1842x1026 , all the tabs across the top for dropdown menus are tiny and barely readable, The rest of the gui seems ok.
Its like when you change your monitor resolution from 800 to 1024 to 1920 , the desktop icons get smaller and smaller , more real estate , The tabs seem to shrink, barely ledgeable , the drop down menus are ok.! is there an adjustment for this . Thanks DJ
If you are on a PC you can adjust scaling of windows/zbrush via the control panel to make things bigger/smaller
Windows 7 > Control Panel > Appearance and Personalization > Display. It’s set to 100% by default. Try cranking that up and see if it helps
The win settings for gui, I adjusted up from 100% to 125% , that ate up my desktop real estate, reloaded , saved user interface from past, with win set back to 100%. Its better, only problem when I open Zbrush the top quarter of inch, goes off monitor, and I have to minimize Zbrush, then open window to full size and it fits.OK Work around for now!
