RH_ZIncrementalSaver v1.0
This Zscript saves the current selected tool with an increment in its filename.
Installation:
Just put the “RH_ZIncrementalSaver.zsc” file inside your “Zstartup/Zplugs/” folder, if it doesn’t exist you may have to create it.
The script will be loaded every time Zbrush starts up. If you have Zbrush running while you are installing the Zscript just load it manually from the Zscript menu.
How to use it:
When the Zscript is executed it adds Subpalette under the “Tool” menu called “Incremental Saver” with a button in it.
To run the Zscript you can press the button or use the default shortcut “CTRL+S”.
The first time it runs, it will prompt a “file save” dialog, just find the folder where you would like to save the file and type a name for it.
Once you have done this the script will save the file in the same location and with the same file name plus an increment.
Ex: Oringinal File “ Test.Ztl” - Incremented File “Test1.ztl”, “Test2.ztl”…
When you change the selected Tool and run the script it will prompt again with a “file save” dialog to save the new selected tool.
Download RH_ZIncrementalSaver_v1.0
RH_ZIncrementalSaver_1.0.zip (24.2 KB)
