Hello all,
I need some help. What is the best way to create this structur?
For the blue ribbon-like structure (been a while since high school biology) probably diddle with the curve brush to lay down the snake-like structures as viewed from “top”… or on a flat plane with its subdivision bumped up, draw the masking shape to ultimately extrude an initial worm-like structure out of it. Since the resulting worm is flat in any two directions, scale it in the third dimension to achieve the wall-like ribbon shape. Combination of incremental scaling and repeated dynameshing ought to do the trick.
The nucleus and mitochondrial shapes are relatively easy by comparison. The yellow tubes would just be cylinder forms that get knocked around by the move brush to look more organic. The outer blue shell of the cell can be shaped with the snake hook.
Thank you very much for the creat tip.
