I downloaded ZBrush, went through the set up process, and nothing happened. Not even the initial startup happened… I’ve re-done the set up process like ten times now, and un and redownloaded it, and reset my computer a few times but nothing happens. What do I do here?
Hi @lxiv64 Welcome to ZBrush Central!
Make sure you disable any anti-virus you have running as well as Windows Defender before you download and while you are installing ZBrush. Also, see if Installer Doesn’t Start applies to you. If it still fails after that, you will have to contact ZBrush Support for a definitive solution… Good luck!
Hello @lxiv64
You will need to contact ZBrush Support for technical issues with ZBrush. Technical support for ZBrush is not provided over the community Usage Questions forums, and other users won’t be able to assist you.
I’m going to close this thread to eliminate any expectation of further assistance here, and to encourage you to go where you need to for assistance with this.
Thank you!
