Need help to delete custom menu?
Hello,everybody.
Is there a way to delete custom menu?
I didn’t find it.
To delete a custom menu, do not save your interface. Just restart ZBrush and the customization will be gone.
If you have saved your startup interface with a custom menu that you no longer want, you will need to delete the CustomUserInterface.cfg from your main ZBrush folder. For this reason, it is recommended that when you are working with creating a new interface you actually save it under a unique name (using Preferences>Config>Save Ui) until you’ve created something that you’re fully satisfied with. This makes it really easy to create a WIP interface, tweaking it as desired until you’ve arrived at something that you really like. Once you reach that point, you can then load it and press Ctrl+Shift+I to make it the startup interface.
