I began to use nanomesh, it’s cool, but…
Why is the number of instances limited to value of 1000, which doesn’t cover the whole mesh if you set the size of the instances to a small value.
I find this very limiting.
If I want to have a surface filled with small pebbles, it is impossible to achieve for me until now.
Is there a way to crank up instances count above that point?
Thank you
