Hello Zbrushers
Try this link http://alphabet.tmema.org/
You will create your own Alphabet !
As the result is a True type Font you can enlarge it and Import to Zbrush and make some crazzy Alphabets
With Alpha-Century method you will make wondeful dropped initial letter or Landscapes !
For me, I can’t, because just Zbrush Demo
Here is an mini-example of the result (calligraphy in this), try it, your will be astonished !
Pilou
Very cool!Thankyou.
Well F.P.this thing looks pretty darn neat but when I press launch the machine nothing happens and right clicking to to get to open link window gives a big blank page with a little icon-I’ve e-mailed them as to possible
solutions-but thought maybe I’d see if you might offer a fix to the problem.
when i checked that url earlier today and learned what its all about i was thinking of you, rhom, right away i hope you will work that problem out asap and let us see rhomysteries asap! thanks so much for that tip, Pilou! i am looking forward to reports of others before i download as with an pre-osx it needs some more shareware to make it mac-tt.
- juandel
Hi Rhom
No particular problem.
The applet loading and you draw some lines and your alphabet is automaticly created !
Maybe your system on your computer is not absolutly compatible ! See the FAQ.
Before resolving your problem, you can download many examples of True Type Font in the Archive !!!
Juandel : I am waiting for your Letter’s landscape
Pilou
Thanks you guys-one of the creators e-mailed me back mucho pronto and said it might be a java enabling thing so now I’ve got to figure
out if I’ve got java enabled.
I tried today, but it died on me too Rhom. My IE 5.0 Java setting (which I am disinclined to change) is set to High Security so that may be the answer. Only odd thing was, the applet obviously started to run, then died before anything appeared on screen with an array index out of bounds exception - not what I would have expected from just a Java security setting incompatibility.
