My menu has disappeared, tried resetting my ui, then re installing and its still gone. I am fairly new to zbrush so any help will be greatly appreciated.
I am attaching an image of what it looks like just in case.
Thank you!
Thank you!
What menu?
That looks normal to me.
Sounds like you may be referring to your tool palate. A lot of palates in zbrush are contextual. So for the tool palate to populate you need to first select a primitive or poly3d mesh from the list of tools in the tool palate. Then the tool palate will populate as normal.
