Multi Map Exporter-Normal Maps exported to MODO help!!
Could someone please advise as to the best settings to export Normal Maps to MODO using the Multi Exporter…
Thanks
ZB 4R8 P2
I used these settings in ZB to export UDIMS into MODO.
As you can see I am getting errors in Modo. What am I doing wrong in ZB.
I remember a while back, people suggesting to flip the green channel (FlipG). That might be causing the color correction error in Modo.
zber2
Thanks, I will give it a go…
zber2
Tried with FlipG
1st image shows just Normal Map UDIMS applied
2nd image shows Normal Map UDIMS with glass translucency applied in Modo
Where the Normal Map is light grey it is not translucent where it is dark grey it is translucent.
Same if I add a colour map the light grey Normal Map Udims are opaque and does not show the colour.
Lost!!
