[attach=207652]MME_header.jpg[/attach]
Note: all plugins are now included with the ZBrush 4R7 installer. If you did not install a plugin then run the installer again.
For the latest information see the online docs here : http://docs.pixologic.com/user-guide/zbrush-plugins/
Multi Map Exporter is designed to automate map creation and export for your model. Settings can be saved and reloaded so that you can quickly set up the plugin and then leave it to export the maps, freeing you to spend more time creating your art.
This plugin is available with ZBrush 4R6.
Installation
The plugin is automatically installed with the standard installation of ZBrush.
Frequently Ask Questions
Q: I don’t see Multi Map Exporter in the ZPlugin palette.
A: If you did a custom install of ZBrush then run the installer again and make sure you install the Multi Map Exporter plugin.
© 2010 Pixologic, Inc. All rights reserved, Pixologic and the Pixologic logo, ZBrush, and the ZBrush logo are registered trademarks of Pixologic. Various patents pending. All other trademarks are the property of their respective owners.
