Hi guys, I´m having the following problem, my move brush works but it moves the surface just a touch, I tried different configs, but nothing seems to work. I suppose it must be due to the sistem units ,. I use 3dsmax.
For example, when I use “millimeters” for my units scale and make a box 2 mts high and export to zbrush, the move brush doesnt move the points so much.
I know I could just use another sistem unit but,
Is there a way to use the sistem unit in mm and make the move brush to work correctly?
Thank in advance.
