hi guys, i was wondering if there is any way i can have my mouse wheel control Z intensity , brsh size etc values. any ideas guys… :idea:
No technique that I know of.
there must be some way, how can they mis it?..any keyboard keys that increases n decrease it like a volume fader in players if not mouse wheel.
thanks marcus
himarcus i used ur plugin but still i have click n drag to increse or decrese th values.should i reinstal n try again?
First check that you have the plugin buttons. They’ll be in the ZPlugin menu under ‘Marcus Tools’ and called ‘Adj DrawSize’ and so on. If the buttons are not there then you haven’t installed the plugin correctly. If they are there then you may need to assign hotkeys to them. Ctrl+click on a button and then press the hotkey you want to use. If you use ‘S’ for Draw Size it will overwrite the original hotkey. Remember to save the hotkeys before closing ZBrush by pressing Preferences>Hotkeys>Store.
Once you have the plugin installed correctly, hold down the hotkey and then move the mouse from side to side to set the value. You shouldn’t need to click (unless you downloaded the ‘Old version’ which, IIRC, does work that way).
HTH,
