when go down to Level1 to use the Morph Brush the Mesh gets to his orginal form. But then when i step up to the highest level all the sculpted stuff is still there.
Can i not remove this with the Morph Brush ???
Thanks, Sticky
Thanks, Sticky
No, you can’t. The reason is that adjusting level 1 makes broad changes to the mesh. That’s the whole point of multi-res editing. For example, if you had a dragon where you’d sculpted a bunch of details for scales and stuff before you suddenly decide you’d like the jaws to be longer. By going to level 1 you can accomplish this change by moving just a few points. Back at max level, all the details will have moved to fit the change.
So edits at level 1 don’t remove changes at max level. They move those changes.
In order for the morph brush to be able to be used to remove details, you’d need to store a morph target at the level where the details are, before you sculpt them.
Another option is to create a layer before you sculpt the details. Then if you don’t like them you can delete the layer. You can also adjust its intensity to make the details stronger or lighter. Layers are your friend!
Glad you ask: here is the trick.
and bypass the info stored on each subd levels.
thanks for the trick,
works perfect
