More often Zbrush 2019 will not show any polygroups
Hello,
More often Zbrush 2019 will not show any polygroups. Only wireframes will be displayed. What only helps is to save the Ztool,restart Zbrush and reload the file.
Initialize does not work. I can not accurately reproduce the error. It occurs more by accident. Lastly, after running Zremesher 3.0 for the second time with Polyframe on,
but also using ZModeler,switching to Move Brush with Polyframe on.
OS Win 10 Pro 64Bit
Version 1809
Build 17763.379
512GB SSD
64 GB RAM
VC 2005 2008 2010 2013 2015 2017 are installed (X86 and x64)
If you’re activating polyframe mode by clicking on the GUI button, be aware that at the top of that button there is a toggle for the polyframe “fill” portion that can easily be hit by accident, depending on your screen resolution.
I have just tried the different variants.all these years i have never noticed, that these are tiny little buttons.:o
I will still observe that but that could actually be the solution.
many thanks for the helpful answer.:slight_smile:
No problem. Using the keyboard shift+F shortcut would avoid this issue if your screen resolution/button size makes it difficult–though the latter can also be adjusted in the ZB preferences.
