Take a look at the following bit of code:
The first line is a debug statement to ensure that the active layer at that point is layer 1.
The next few lines do things to layer 1 (supposedly).
The final line is to confirm the active layer is still layer 1.
The problems are:
The first debug line indicates that the active layer is in fact layer 1; but the second debug indicates it has been changed to layer 3, even though none of the intermediate instructions should have caused a layer change.
The Layer:Clear command has no effect on any layer.
The CanvasClick command does, however, draw correctly on layer 1.
After execution, the active layer is in fact layer 3. If I remove the lines after and including the Layer:Clear command, the active layer is left at layer 1. In other words, I’m pretty sure that my get active layer routine is functioning correctly.
So I don’t know what the heck is going on. Any insights?
Thanks,
Ken
