Moonlight Dancing Fishes - Cufflinks
Hi all,
This is my design of fishes dancing around the moon mirrored at the water.
I like design useful product something what is not existed only in virtual but also as real form.
I hope you like it.
Modelling: ZBrush
Rendering : C4D + Corona Render
Cufflinks are cast in Sterling Silver + Enamel + stones. Ready for bespoke orders.
Contact: [email protected]
He Henryk, good job, delicate and great taste
Thank you, Nacho :wink:
Hi! How can I buy such cufflinks?
Hi! This is exciting and high-quality work. But I want to note that you need to be able to wear cufflinks, and the main rule is to make them not evident and noticeable at the same time
Depend from the size… From client expectation. Are you working in the industry?
Only bespoke order. If you are interested lets contact privately
The correct coordination of the length of the sleeves of the jacket and the cuff of the shirt achieves this. The difference in size should be about one and a half to two centimeters; that is, the shirt should look exactly that length and no more. And if everything is correctly coordinated, then only at specific points in the position of the hands will cufflinks be visible, and this is called the correct wearing of cufflinks. I usually forget cufflinks on sites like https://www.gentlemansguru.com/product-category/accessories/cufflinks /, but if you have your website, I would be happy to choose something from your works.
