I’ve been using this for some time, but I’m not 100% comfortable with a lot of zbrush’s interface yet.
I finished sculpting detail into a model, but when I open the project I thought I saved it to, it only contains the low-poly model. This is not a case of mixing up Documents, Projects, or Tools. I am using Project saves exclusively while I work, and this is a case of me being only 50% certain the project was saved. :o
Some things worth noting:
- The project file is still 77MB, causing me to think the data is still there.
- The project file thumbnail shows the high-poly version, also causing me to think the data is still there.
- There are no hidden subtools.
- There are no higher subdivisions.
The Zbrush interface still confounds me, so if you can think of a place I haven’t checked, or some feature that might be hiding or storing all my detail somewhere that I don’t know about, please share your knowledge. Thankfully if the work is lost it’s not too much, but still frustrating (though my fault if I just didn’t save the thing when I thought I had).
