Missing MatCap Icons
the materials function, but the icons are missing.
What are some things to check, is tere a way to rebuild the icons?
(this is after new install of ZB4R7p3 x32)
Same thing here. OK, I’ve found that if I ‘Init ZBrush’ that the icons come back. I do lose the default material (other than Red Clay) that I have in my DefaultZScript, but if click on the ‘DefaultZScript’ button to load it, the alt default material comes back. Yes, annoying, but that is the workaround, for now, I suppose.
OK, Update: I was able to add a default sphere with the correct default material/ matcap icons showing up and then do a ‘Store Config’ and ‘Save as Startup Doc’ and now everything loads correctly :smiley:
