Mirroring using a specific vertex as the center point
Is there a way to choose a vertex as a center point for Mirror and weld function?
Moving the model untill the vertex I want is in the middle of the grid can be bit of a drag when it is important to be accurate.
The Gizmo snaps to vertices so hold ALT and tap the Gizmo on the vertex of interest. Then click the Gizmo Home icon. The mesh will translate without rotation so that the selected vertex point resides at the origin. Then Mirror and Weld.
Thank you! That was so easy and so helpful!!
