You can see here the right object is the original and can clip without worrying about the axis.
Hi. I had this idea to make mirrored instances using the array feature because I was frustrated that clip,mask,trim curves always interfered when crossing the axis of mirrored objects.
I brute forced it with some limited success - hoping someone can take a look and advise on making it better. Thanks!
Array_MaskedX.txt (2.56 KB)
